| Message |
if you park your car inside a garage don't be surprised if it smells like gas all the time. All the gas vapor the cc collected will just escape into atmosphere once the canister has collected so much vapor to the point of saturation. If you don't want that then go ahead and remove the screw then plug it in and make sure that it's connected to the balance tube in the back. If you don't care then I say while you're in there just delete the whole thing, benefits are better flow behind your intercooler, less spots for air leaks to develope, and less weight up front.
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to in-politely tell me how wrong I am :) "The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy (discussion on ptu relocation) "No good reason to put it there anyway. -Bernie (NoVA) False -vorpalZ False. -Bernie (NoVA) You're correct, there are 3 good reasons -vorpalZ False. -Bernie (NoVA) Wow, right again, just remembered another, make that 4 -vorpalZ" XD
